My new SZ1XP/C has few problems with built-in cam and generating heat even if I run few programs.
My laptop built-in cam works fine, when used normally but when I try and broadcast through messenger or other utilities, it goes fine for sometime but hangs in the middle making my whole application to end.This really irritates sometimes, as I have to kill the whole application.
Other problem is the heat generation. I can quite feel the laptop generates sufficient heat quickly even when i run only very few programs . I tried once working on the laptop on my lap and i was feeling heat sooner ( 10 mins~).. Is there any VAIO / Windows update to fix this problem?
Cheers---
Download MobileMeter if you have any feeling of doubt about heat
