profile.country.el_GR.title
google2012
vpc-yb2m1e ssd upgrade
Hello! I want to install an ssd :smileycool:.  I cannot determine what is the version of the disk controller. The only information I have found is the following:
model: SB700/800 SATA CONTROLLER ACHI MODE
interface: SATA revision E1
specification: 1.10
maximum sata mode: G3/sata600
What version is the sata controller? (sata I,sata II, sata III)
Does anyone use an ssd? What version and model?
Hi google2012 and welcome.
Your model uses the AMD E-350 APU and has the AMD A50M Fusion Controller Hub Chipset.
The A50M Chipset supports SATA G3 which is SATA 600 which is 6 Gbit/s which is SATA III.
:wink:
:wink:
