I have only just bought this laptop and have previously owned a Sony Vaio which is why i chose to buy another Sony, however i hate it already! My previous excellent experince has been tianted by this one.
The keys on the laptop dont register when i press the, i have to almost bang on thekeys to get them to work and even the they still dont work properly. This has been happening since day one! I use my lapto a lot because i am a studenan writing up essays and reports is difficult and time consuming whe i have to keep going back and checking that the keys have registered...even typing this i have had to correct it several times....its annoying and i doubt me banging on he keys is helping much either but i have no choice.
Also there is a metalic kind of sliding then clicking noise that happens periodically that is coming from the inside of the laptop.
Any ideas on a solution? I bought the laptop 25th Sept and its been doing this since i bought it.
I don't think there is a simple solution.
It sounds like you have a hardware problem with the keyboard or its cables and it may need replacement. In theory you should be able to take it back to the seller and ask for a replacement within 28 days of purchase if it is faulty.
Not sure about the clicking - hard drive problem perhaps?
Alternatively, contact Vaio Support and ask their advice.
