Where can I get the PMB (photo sort) program to relaod onto a replacement C Drive?
robhaine
Where can I locate the PMB program (for sorting and categorising photos) for relaoding onto a replacement C Drive?
Welcome your help plse.
If you have installed your new drive using the Recovery Discs you made when the Vaio was new, PMB should be automatically installed.
If you have a Sony camera you can download the original software from the Support Page for that camera.  Go here and type in the camera model: -
http://support.sony-europe.com/main/index.aspx?site=odw_en_GB
If you did not make Recovery Discs and do not have a Sony camera, you can try downloading it here but I am not sure if it is the fully featured version or if it will work on your Vaio:
http://support.sony-europe.com/dime/downloads/downloads.aspx?&f=download_manager&site=odw_en_GB
:wink:
