Please can somebody telll me if my laptop still comunicates with my router or other devices even when the power is turned off. My laptop is a VGN-FS415M
Dear friend,
i dont think that your laptop could actually communicate with your router while it is turned off! Maybe you should consider the possibility of someone (maybe a neighbur) is using your router. NB some routers have the ability to "detect" movement around them and you may realise that if you notice the WLAN light blinking while your PC is turned off.
I hope you find the answer and let us know
