Hi!
I just purchased a new pair of Sony h.ear on 2s and after pairing it up I realised that the touch controls were partially not working. The volume up and down swipes work just fine, but the play/pause and skip track functionality are not working. What can I do to fix it? I tried re-pairing already and it did not fix the issue. I am using a xperia xz if that helps with diagnosing the problem.
Hi MSMarcell,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi MSMarcell,
Have you tried resetting the headphones? Here are the steps:
https://helpguide.sony.net/mdr/whh900n/v1/en/contents/TP0001513197.html
Win_88
@MSMarcell wrote:Hi!
Thanks to everyone who replied! The issue turned out to be with my phone and after resetting that, the touch controls started working as intended!
