Hi all
I have a Sony NW-A105 mp3 player and cant figure out what the 2nd slot [next to the headphone jack] is.
Can someone confirm it is some kind of security/ chain system to attach the device, or an antenna.
Have looked in manuals and on search engine blah, but cannot find anything. - I deally i would like to attach a chain so I dont lose the media player.
Arrangement of bottom of device for illustartion purposes only :
o o o o
Headphone jack Unidentified port USB -C MicroSD Slot
Jimbob
Solved! Go to Solution.
Hi, check this link from the Help Guide: https://helpguide.sony.net/dmp/nwa100/v1/en/contents/TP0002432968.html I believe you mean the strap hole?
Hello @jimbobjim,
correct, the slot is there to thread the loop of a wristband or lanyard trough.
Bottom of the NW-A105
- Nic
Hello @jimbobjim,
- Nic
