SRS-XB22 Auto turn on when there is Aux signal?
salis10
Hi, can you please let me know if this portable speaker has the ability to detect if there is a signal coming to its Aux input, and if yes, to turn the speaker on? This would be really useful, as I would like to connect a device like Chromecast Audio or Echo Input to the Aux input of the speaker, so it will be great if this device can automatically wake up the speaker. Thanks
IamNic
Hello @salis10,
no, the speaker doesn't have this function.
You need to turn it on manually.
- Nic
