WF-1000XM3 right earbud mic stays on while ambient sound control is turned off
profile.country.FI.title
WestmanR
So does anyone have a similar problem with their WF-1000XM3.
I noticed that if I turn off Notification & Voice Guide and then try to switch with my left earbud to Ambient Sound Control off, the mic in my right earbud will stay on until I long-press the left earbud to turn on listening mode. After that, the right earbuds mic will also turn off permanently.
Can someone test this setup out and report if I have a faulty device or if the software is just a buggy mess.
To test this:
1. Turn off Notification & Voice Guide
2. Put the buds back in the case and reconnect them
3. Change mode to Ambient Sound Control off
4. Test the right mic with a finger (or if your outside it should pick up wind sound)
At least in my testing, if I repeat the previous steps it will stay on.
Tags (2)
Pascale_F
Moderator
Hi WestmanR,
Welcome to the community.
I'll just see if I can find any assistance with this. In the meantime though, maybe someone else may have some ideas.
Thanks,
Pascale
Vanilla_
Hi WestmanR,
I've not come across anything similar. Have you tried to reset them at all?
https://helpguide.sony.net/mdr/wf1000xm3/v1/en/contents/TP0002289926.html
Vanilla_
WestmanR
Doing a factory reset fixed it for me at least for now. :slight_smile:
