Hi folks,
I got a set of WH-1000XM2 headphones for X-mas.
They work when I connect them to my iphone. They work when I connect via the wire. They don't work when I try to connect them via bluetooth.
I can connect them bluetooth (see photo)
But I don't have option to output (see photo)
I contacted Sony support but they were not much help TBH.
Any help appricated.
Hello @blahboy,
right click into the last window and tick "show deactivated devices" and "show disconnected devices".
Maybe that helps.
- Nic
Turn on the headset, when you pair the headset with a device for the first time after you bought it, or after you initialized the headset (the headset has no pairing information). The headset enters pairing mode automatically.
When you pair a 2nd or subsequent device (the headset has pairing information for other devices), press and hold the button for about 7 seconds.
Make sure that the indicator flashes blue and red alternately after you release the button. You hear voice guidance “BLUETOOTH pairing”.
Manolo
Hello @Marino.Manolo,
according to the screenshot the headphones are already paired with the Laptop.
- Nic
"I can connect them bluetooth"
Ops!... Sorry...
Manolo
