I have had these headphones for about 4 months and they worked perfectly, but the power button will no longer turn on. When it is rattled I can hear something is lose so I think they just need a simple fix. How would I go about getting them fixed under the warranty?
Many thanks
Solved! Go to Solution.
Hi Becky.night,
I believe you can send it to Sony centre to get it inspected. I've found their official website here: http://www.sonypencoed.co.uk/
Best regards,
Vanilla_
Hi Becky,
Welcome to the community.
I'll look into this for you - sounds frustrating. Someone else in the community may be able to advise in the meantime though.
Thanks,
Pascale
Hi Becky.night,
Best regards,
Vanilla_
