Does the z3c work with 3g and can it make regular calls and send texts in Sweden?
Solved! Go to Solution.
It should normally work in Sweden on 3G.
| 3G bands | HSDPA 850 / 900 / 1700 / 1900 / 2100 - D5803 |
| HSDPA 850 / 900 / 1900 / 2100 - D5833 |
Which model do you have?
I hanv´t bought one yet because of this uncertainty.
I friend said that even though it has 3g/4g it lacks the antenna to make regular calls and recieve texts. Otherwise why call it a tablet?
So does it have an antenna? Is it possible to use as a regular phone? (If there are several models, I would need the model that is capable of regular calls)
I have a subscription with "Telenor" in Sweden for 3G.
So you are talking about the Z3 tablet compact not Z3 compact? It is compatible with calls:
| 3G bands | HSDPA 850 / 900 / 1700 / 1900 / 2100 |
Ah sorry, my bad. I just releaized that i didn´t write it clear enough. Didn´t even know there was a Z3 comact. Yes, i mean the Z3 Tablet Compact.
Hi Tuskland,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
The Xperia Z3 tablet does allow calls, however there is no Ear speaker, so you will need to use a headset or use the loudspeaker when making calls.
I hope this helps.
@Jake-SonyXperiaSupport Thank you for the information about using a headset or loudspeaker.
@uliwooly nice website!
