3g and regular phone calls - Sweden
tuskland
Does the z3c work with 3g and can it make regular calls and send texts in Sweden?
24 REPLIES 24
profile.country.RO.title
_alexdon_
Of course,on 2G or 3G or 4G.
alexdon
tuskland
but the cheaper wifi version, for sure has only wifi connection right? no GSM network availability, maybe theres even no slot for a sim card.
_alexdon_
Yes,the wifi only version cannot be used for calls.
alexdon
Rickard
Master
As already mentioned, if you buy the LTE-version you can use it for calls but as i'm from Sweden i can confirm that it works with Telenor SE.
But if you buy it from an operator they may ship it with a SIM card that only includes data and have no voice support so you may need to get another subscription or contact the operator to have it enabled in the subscription.
tuskland
I bought it and it works flawless. Didn´t have a nano sim card though, so Telenor provided me with a new one, and Telenor 3g is 2100mhz and the z3ct supports it well. It´s so nice to have a tablet and phone in the same deivce. Cheers and thanks for all the help!
