Does the z3c work with 3g and can it make regular calls and send texts in Sweden?
Solved! Go to Solution.
Sorry to keep this discussion going-
I rechecked a resellers homepage of the phone where it said "supports voice calls: no"
And therefore asked my friend who uses sony z3 ultra again. He said that the z3c tablet doesn´t support calls and text messages through GSM..just regular data through 3g and 4g.
He might have wifi only version of the tablet.
No, he only had the z3 ultra, but he said he was sure even the 3g/4g version of the tablet doesnt support GSM calls and texts.
Can you confirm that it does support it? 😮
There is no such device as Z3 ultra. Only Z ultra or Z3.
Sorry again, i meant z ultra.
Z ultra can be used for calls normally,not only via mobile data.
I have no questions about z ultra though. My Q only regards z3c tablet.
The tablet can be used for calls/messages,but you need to either use a headset or loduspeaker as there is no ear speaker. Jake told this,which means it is compatible.
And those calls can be made through the GSM network? Right?
That´s the most important question i have.
