infuriating phone
infuriating phone
my x1 wont switch on, only goes to checking sim, then resets itself. never stops doing it. Can somebody please help?
5 REPLIES 5
Jeff
Enthusiast
How long does the phone stay on after power on?
Have you tried turning on the phone without having the SIM card (or memory card, to test) in the phone? We can determine where the issue lies.
Concerning the possibility of software problems, as long as you can get it to stay on, this may resolve it.
If not, a hardware issue is likely, where are you located? You'll have to call local support via these phone numbers: http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
like i said it doesn,t stay on. it just switches itself off, and immediately it starts the same cycle again
I have tried without sim and memory card, but to no avail. i am situated in South Africa
Jeff
Enthusiast
Alight, give the local office a call and let me know what happens: (0861 632222)
Thanks for the info. Will do so.
