i have been using my xperia x10 for the past 4 weeks now but unfortunately i forgot the unlock pattter. I have tried all what i could, i downloaded the Sonyericsson service update to reset or repair it , i was doing it , i hold the C back key button and it came up with window needs to intall driver software for your SEMC USB FLASH ... Pls what can i do? Where can i get the SEMC USB driver? or is there any option to Unlock it ? Please help me out.....Please please am crying OUT FOR HELP....PLSS
PLEASE HELP ME
On only possible to unlock the pattern password with either the correct pattern or your Google login.
The SEMC USB FLASH drivers are included within the Update Service program.
If they fail to install I suggest that you first test with using another USB port on your PC, if the problem remains you could try running the update via another PC computer.
Note that Update Service is not supported by Windows XP 64bit. If you are running on Windows XP 64bit it could cause these kinds of drivers problem for Update Service.
