I currently own a Sony Ericsson Cedar, and I was wondering if it was possible to save the entire conversation history of a certain contact? Right now, I can only save the inbox folder and the sent messages folder separately, which is quite annoying. The Cedar also seems to save the timestamps of messages, so saving the whole conversation shouldnt be a problem, only, I cant seem to find a software that does it. Any suggestions?
According to your phone's specs, you should have the Conversations feature: Main menu--Messaging--Inbox--click left or right--Conversations: these should already be saved for each contact you have texted to and from.
Oh, sorry for being vague...I meant to say, saving entire conversations on the PC.
Thanks for the reply though, Chris.
No, you can't save the Conversations on PC--only individual text messages through PC suite.Unfortunately, these Conversations are not visible on PC suite.
Oh...thanks a ton, man...cheers!
