Dear Sir,
i have bought Xperia T2 Ultra Dual sim today...
according to your website specifications page, it should be ACTIVE SIM supporting recieving calls on both lines simultaneously , while when i am having call on SIM1 , SIM2 is always out of reach and vice versa!!!
please advise!!!
Indeed it is active
http://www.sonymobile.com/global-en/products/phones/xperia-t2-ultra-dual/
Handle calls on both SIM cards
Dual SIM smartphones come with many advantages. They allow you to separate work from play – and handle your calls more cost-efficiently. With our new dual SIM feature, you can keep both SIM cards active at all times – meaning that you can talk on one SIM, and still receive calls on the other, instead of going to voicemail.
According to GSM arena,it is dual standby:
http://www.gsmarena.com/sony_xperia_t2_ultra_dual-5968.php
Most of the xperias are like this,if not all.
That's what I thought, this is odd, perhaps a Sony moderator could explain
or you can contact Sony directly
I did forward this internally some time ago to have the text on our webpage made more clear but there's been no change yet.
The text on our webpage is referring to the function called dual SIM reachability where the phone forwards calls to the other SIM during calls. This means that the phone will forward calls made to SIM2 to SIM1 when you have a call on SIM1 and vice versa. The phone is a dual standby phone.
this is not what happens...
whenever you are using any SIM the other is unreachable !
what !!!!!
so its not as mentioned!!!!
this is scam!!!!!
its clearly listed on website, and you say you have requested that and text were not changed!!!
thats really not sony image at all, this is total scam!
so, what should i do now after buying mobile for this 1 option! what should i do now!
shame on sony mobiles!!
please Mr. Moderator, i need kind of effective solution to my case because manupilated words is act of scam companies and i think sony is not one of them!!!!
i need solution please!
To use this feature you need to enable Dual SIM reachability under Settings -> Dual SIM settings. You operator(s) and subscription(s) must also support call forwarding and call waiting.
When this is enabled you will be able to to receive calls on both SIM-cards even when you have an ongoing call.
I'm sorry to hear that you feel misled by the text but if the dual SIM reachability feature doesn't meet your needs i can only advice that you contact your local support team to see if they can assist you.
i tried to reach them
and they saracasticly responded, I HAVE TO READ INFORMATION CLEARLY ON WEBSITE!
which i believe i did!!!
so, no solutions?
i just threw my money for scam or what !!!!!!!!!!!
Also, please check your website! because this is total scam, i just double checked it!!!
i will sue you!!!
Dual SIM smartphones come with many advantages. They allow you to separate work from play – and handle your calls more cost-efficiently. With our new dual SIM feature, you can keep both SIM cards active at all times – meaning that you can talk on one SIM, and still receive calls on the other, instead of going to voicemail. This gives you the option of putting the first call on hold while answering the one coming in. So you need never miss a call. You activate the dual SIM feature when you set up your phone. If you add your second SIM card later, you can always access the setup guide from the Settings menu.
