Android 5.1.1: Broken encryption of exFAT SD cards
avolkov
Hello,
After upgrading of my phone to the 5.1.1 I've tried to (re)encrypt my phone and card, but without any success: card become unreadable and all data on it  disappeared. Card's reformatting doesn't helpful since card became unencrypted and any following reencryption lead to the same result: unreadable card. If someone have solution for this regression (except downgrade) please tell me.
Thank you
Andrey
Upd: As I've answered below, internal phone's memory has been encrypted successfully, problem only with SD. Also before wrote this post I've tried to do next things:
  - factory reset couple times
  - reinstall firmware by Companion
  - install AOSP
And probably Cyanogen has not problems with encryption, but I need for the worked camera.
Rickard
Master
We have now tested this with a Sandisk Ultra 64GB SDXC formatted with exFAT but we can't replicate this on the latest firmware so please test your card with the software i mentioned. Damaged blocks on the SD card could cause something like this.
14 REPLIES 14
Uliwooly
avolkov
Maybe I did not describe the problem clearly: the phone is properly encrypted, but the card doesn't. Nothing common with Z3 case.
Uliwooly
@avolkov
The phone its encrypted but not the SD card, is that what you are saying?
avolkov
@uliwooly wrote:
@avolkov
Yes, exactly.
avolkov
And, as far as I can see (due to empty search results), this problem appeared only with exFAT cards.
Uliwooly
@avolkov
If I recalled it was an Android issue but I'll keep looking
avolkov
I'm afraid that it's Sony creation. Half of year is more then enough to bump and publish such problem.
Uliwooly
@avolkov
I'll escalate this, perhaps we'll get an official answer.
avolkov
Thank you
