How can I change the color design of top pane?
VB280775
After some? updates, the color of top pane has changed by itself. Can I change it?21212.jpg
Hampus
Champion
As far as I know, you cannot change color of the notification bar when you are inside an app. Just like @uliwooly said, there might be third party apps that can do so.
But this notification bar, will adapt the color of the app that you open. For example, if you go to YouTube it should be red > If you go to Facebook it should be blue. Make sure that all your apps are updated to the latest version.
5 REPLIES 5
Uliwooly
@VB280775
you can't unless you use a third party app
VB280775
This is system panesketch-1441787552755.jpg as I know.
Hampus
Champion
VB280775
Thank you!
Hampus
Champion
You're welcome. Slightly_smiling_Face
