Pre-installed Apps any use?
ArunAryappallil
Team,
Please help me to remove pre installed applications like Google plus,Evernote and Google Keep from my xperiaz2(Lollipop version)
Regards,
Arun
Uliwooly
@ArunAryappallil
Settings > apps > all > select the app > uninstsall, if you don't have the option to uninstall it you could disable it.
Uliwooly
@ArunAryappallil
saeedted
You phone came with Evernote pre-installed? Is that from Sony or carrier?
Uliwooly
@saeedted
Preloaded apps vary per carrier and region.
