Solved! Go to Solution.
http://www.howtoquick.net/2012/08/how-to-activate-smart-gprs-settings.html
@ajsakura
If you have wifi try with WiFi on, if not then you could enter them manually
settings > more > mobile networks > access point names > enter the info > save
Who is your carrier and from which contry?
Carrier/network
Anytime
