My phone suddenly turns off and the battery is at 85%?
It turned off when I was trying to type this message.
It is water proof, so I cannot remove the battery.
Any suggestions please?
Solved! Go to Solution.
Press and hold power & volume up for 10 seconds
if that doesn't work, open the SIM cover > press the yellow button for 2 seconds, gently.
I have tried your first suggestion.
I will see what happens.
Thank you so much.
Your first suggestion didn't work.
I tried your second one, yellow button, three times. So far so good.
I'll keep you posted.
I tried both suggestions. They didn't work. My phone won't even turn on now. Thank you for your help.
