Yesterday I updated my Z2(D6502) to lollipop through PC Companion.
I use 3g connection. If I restart the phone with 3g enabled i get message there is no service. If I switch to 2g and 3g it starts working.
please check
Solved! Go to Solution.
Have you also tried making a repair of the phones software as suggested by SophiaW?
If that doesn't help, please send me a PM with the following information and i'll forward it for further investigation:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
@Makarand1881 Try to select network operator by manually for the first time and then operator logo will appear in the lock screen, Its worked for me
Rickard,
yes I have done the repair as suggested but it did not help. I also did reset through settings.
Below is the information that u needed
Phone nr:
E-mail:
Country: India
Operator: Idea
IMEI nr:
Build number: 23.1.A0.690
My Xperia Z2 phone was working fine before I upgraded it to Lollipop (23.1.A.0.690 Customized PH FTF) three days ago. Now it is not always showing my carrier (Globe PH) on locked homescreen, instead it is showing 'No service'. I checked it on my Settings>About Phone>Status and verified that my mobile state is connected and my signal indicator on home screen is at full bar with an ongoing data connection as seen on the screenshots below. Are you guys having the same problem? Do you have any workaround for this? Thanks!
I think "No Service" is a bug of a new software update (.690) this will temperoraly fix once you manually select your operator,change Flight mode to normal mode or 3G to LTE mode, but after the restart the phone again No service in lock screen will appear, I hope new .726 update will fix this.
Any one updated to new .726 update please confirm is this bug still exists.
Settings then more then Internet settings then Accept then select your network provider and assuming you are connected to wifi then settings for mobile data and MMS should auto download and install fixing this issue
