Im currently downloading Android 4,3 for my Xperia Z1. Once I execute a Factory Reset in my device will the version go back to 4.2 or 4.3 will be the default?
Solved! Go to Solution.
If you perform a factory reset on your device, you will not roll back to an earlier Android-version. You will stay on Android 4.3 in this case.
Hampus is right.
If you want to restore your device to original settings you have to hard reset your device by following method:
Hope it helps you.
