Small App Active Clip, where are screenshots stored?
Blugrn
Over the last year, I have used the Small App Active Clip quite a lot to take screen shots. They used to be stored in a folder named Clipper, but as of August 5, 2015, none is stored there anymore. Where can I find them?
I am using Lollipop 5.1.1, version 23.4.A.1.232.
Thanks for any hint I may get!
25 REPLIES 25
Uliwooly
@Blugrn
Clearing the data will NOT delete any picture, it will delete the thumbnails/cache settings as well as if you have hidden any picture, it will reset the app, but will NOT affect any picture
Blugrn
Master, sorry about my ignorance, but how do I boot on in Safe mode?
Uliwooly
@Blugrn
Don't worry about it, that's why we are here, to help each other
(click/tap on the huge red letters) this is how to boot on >>>>>>> safe mode
Blugrn
Sorry again, but when I press the power on/off button, I get a pop-up with 4 options:
Turn off
Restart
Take screenshot
Take screenrecording
Nowhere I am asked about if I want to reboot into safe mode.
Uliwooly
@Blugrn
That's because you have Lollipop.
You have to long press the power button > then once you get the menu > tap and hold the turn off option
Uliwooly
Blugrn
No matter how long I hold the power button pressed, it does not get out of the 4 options I mentioned.
Uliwooly
@Blugrn
Unlock the screen > press and hold the power button for 2 seconds > you will get those options
Blugrn
No chance, it will not move into any other screen.
Tomorrow, i will try to shoot a video and show it.
Thanks for now!
Uliwooly
@Blugrn
Does the power button work?
