Hello, since this phone is waterproof i wanted to try it under water, and when i putted it under water, while all the slots were closed properly and there was also a phone cover protecting it, my phone turned off and from then it didnt switch on again also after i pressed the power button like 10 times
I have the Z1 Compact and am currently on holiday. Have just experienced the same disaster described above. Water in the sim tray. Every flap was securely covered before taking snaps under water in less than a metre! I checked everything before I went in each time. Very upset because I took every precaution necessary. Any suggestions for what I might do next? Many thanks.
Sony can say the phone is water proof and I have no doubt that the phones tested pased the IP tests. However, in the real world of manufacturing there is likely to be a significant number of phones that will not be waterproof. Now, if you choose to put your phone in water you are opening up a whole world of possible grief. If the phone gets water in it, Sony are most likely to say that you did not have the ports closed. It is then down to you to somehow prove the unprovable and show the ports were closed!
The alternative would be for Sony to stand by their claims and exchange water damaged phones without question.
What do you think Sony's current policy is?
I also have this same, exact problem. My son checked that all the flaps were shut & sealed, used the phone in a swimming pool for a couple minutes, and a little while later the phone was dead. If so many people are having this problem then maybe it is time to take legal action against Sony. How can a company claim a phone is waterproof and when you try out this feature within reasonable conditions and with the utmost care, you kill your phone? Frustrating!
I have the exact problem. Reading on the internet, i'd realized, this is not a 100% waterproof phone. There are too many people with this problem.
I bought the phone, 3 days later, i decided to make a test of this "wonderful waterproof phone", i got into the pool for about 6 minutes, take a several pictures and got out. When i was going to look at the pictures out of the water, the phone turned off.
I tried to turn it on several times but it didnt. Few hours later i decided to plug it on the wall to charge it and immediatly the phone turn on. Now i was happy again.
I started to test everything and it was fine. The next day the microphone and speaker started with problems, and realized that the camera had water inside.
I took it for warranty, and Im still waiting for a response.
My advice for future buyers, is an excellent phone, probably the best right now, the camera is incredible awesome, but DONT... PLEASE DONT PUT IT ON WATER. IT IS NOT A 100% WATERPROOF PHONE.
Hi. I have same problem. I went to the pool and I put it in a water at 30sec!!! And my phone is dead.:smileysad:
Hello had the same issue here. I even bought external magnetic charger so that other than inserting a SIM card and microSD card I didn't really ever open the lids on the mobile. I tried to make some underwater pictures in a pool. The phone was max 10-20 cm under water and max 2-4 minutes. When I went out of the pool the phone went blank, I tried to power it up but all I got was a red light and 3 vibrations. I dried the phone completely with the towel on the outside and opened all three lids. There was no water there so the lids are tight, the problem is somewhere else. The phone was sent to Sony service and I fully expect them to fix it under warranty as after reading many similar posts the phone is clearly not as waterproof as advertised.
they are cheating us, it's waterproof, my phone is dead now i ust try to take some pic in the water (sea) after minutes is dead i tryed to reset it it vibrate couple times and when is tunnig is showing sony again and again when i puted it on charge is giving me red light turn on and off every 6 sec.
dont buy the f*** sony xperia z1 compact
