Internet Connection Bravia TV
H00523143
Can I set up an internet connection on a Bravia KDL32EX503 TV and if so, how do I do that?
Bravia55HX
you can connect this tv to a wireless network using the UWA-BR100 dongle
10 REPLIES 10
Bravia55HX
gofrost
you can also use a ethernet cable depending how far your tv is away from your router
press HOME
tab left to SETTINGS
tab down to NETWORK
select NETWORK SETUP
select wired setup or wireless setup
follow on screen instructions.
etritd
is it a cheap advertising by "Bravia55HX923" suggesting only the 100$ UWA-BR100 dongle and not mentioning the ethernet cable?
well done "gofrost"!
Bravia55HX
whatever floats your boat etritd!
etritd
well... u carry on floatin' sony's boat!
Guys Guys Guys
The whole point of an open support forum is that anyone can chip in with an answer. Everyone has different ideas on things, and 1 idea may not occur to another. As in above. 1 persons idea is wireless and another is a wired solution. Neither is incorrect, just separate ideas on doing things.
Have fun : )
etritd
the point of an open support forum out of Sony site is to chip in with a helpful answer and doesn't occur that a "Master" omits the common knowledge and the cheapest way of ethernet cable
I personally take the ranking system as a pinch of salt. The thing is, we cant all be perfect all the time. For example, on a previous subject, I suggested using serviio. Totally forgetting about Homestream which Bravia55HX923 chipped in later. Whether your a newbie or Grand Master Jedi, who cares really.
Im just simply pointing out that we all have different ideas and ways of doing things that all. :cool:
Bravia55HX
most people would already know of the ethernet connection thats why i never bothered to mention it, so you carry on etritd and throw sarcastic comments and Quinnicus makes a valid point we are here as a community for the community, Sony cannot be on hand 24/7 as they have their own work to do!
