Typing the Login to Netflix
Shansell
Hi
I have a new tv with a netflix icon and the login screen comes up.  But I can't work out how to type in the details.  Any advice?
Bravia55HX
on the log in page press the centre button on the remote then type your e mail and press enter then do the same for the password, i presume you already used the free trial up, i have not used this yet but thats how you log in to it.
Bravia55HX
