A question about FN Button Sound.
profile.country.ro_RO.title
Gabb0411
Hi , i'm using a Notebook Sony Vaio VPCF11C5E. Always when i press FN + F3 ( Volume down ) or any button in combination with FN , the notebook is making a beep , how can i disable it ? I've looked in Vaio Control Center , in Control Panel but i didn't find anything to disable this beep.
rich912
Hi Gabb0411 and welcome.
To disable Fn key sounds locate pi.wav file which should be located in Programme files\Sony\Vaio Event Service. Rename this file to oldpi.wav (or any other name) - no more beeps as the service cannot locate the default file.
Go n-éirí an bóthar leat
rich912
Gabb0411
Oh thanks ,it works.
rich912
Pleased to have been of help:smileyhappy:
