cannot load windows vista after hard disk wipe and erase data
hmistry1988
I want to sell my old laptop sony vaio vgn n31s so i decided to make sure all of my data was erased. I inserted the recovery disk and clicked on VAIO UTILITY RECOVERY  then selected wipe and erase data. After the process was completed ive tried to restart the computer put a message comes up and says 'operating system not found'.
I have a System recovery disk and a application recovery disk.  The system recovery disk loads up the 'system recovery options' its asking for drivers to be loaded but none of the cd's have these drivers.
Is there anything I can do to get windows back on my laptop without buying windows vista again.
Message was edited by: hmistry1988
rich912
Hi hmistry1988,
Try tapping F10, at boot, to enter Recovery Center on the hidden partition. Have a look at the following guide.
http://www.sony.co.uk/support/en/product/VGN-N31S_W/tips-and-solutions
Rich
Go n-éirí an bóthar leat
mithcd
You must be in a tough spot. I would suggest calling tech support here and verify if the disks that you used is the correct one.
Good luck. https://imagicon.info/cat/12-13/vmware_happy.gif
rich912
Hi hmistry1988,
Rich
