Thats very odd. Telephone VAIO Link asap about this. It does not happen on the K-Series laptop that I use.
This does sound like a hardware issue, and should not happen!
Cool, glad to hear you love your VAIO.
Let us know how you get on with Sony Support!:smileywink:
That's pretty bad that they don't know the model.
Hope you get a call soon, rather than later.
I would call this guy again every day.:smileycool:
come to mention it my S3 model does this too but then again its not actually that noticable i hear the fan over anything else!!!
Yeah, do this.
BTW I has a similar problem with a cheap room lamp. I mean there was the same buzzing noise by low brightness. The result was I have bought a new expensive room lamp. And now I have no problems.:smileygrin:
What I mean is, it wouln't be new that Sony tried to use cheap parts for a expensive thing.:smileycool: The PS 2 is the best example for this.
