Hi after suffering total loss of laptop ie no power laptop sent back to Sony under warranty I was told all it needed was a HARD RESET how do i do this in future where is the the button to reset also told it was because i installed extra memory taking it over 512 limit something about a power surge due to extra memory i read on VAIO site PCG-K215M can handle 1012 meg I used specific for the model 512 meg and original 256 would this have caused the problem?
Thank you
John
But it does seem i will have to look deeper for reset button if it happens again, because there is no hole just wondering if it is only accessible from inside the machine
That would be my first laptop without any reset button. There must be a hole.
Trust me to get one without reset hole I have spent evening looking for it even taken drive and memory covers off Thanks for your help lads
John
