RAM measured by the Desktop Gadget.
Will1111
Hi,  I recently activated the Desktop Gadget which measures the CPU and RAM usage.  I was surprised to see that the RAM dial is always somewhere between 24 and 27%.  Is that normal?
I thought that when you first start up a computer the RAM is empty, but the dial on my computer is at around 25% right from the start.
Will
Hi Will,
It is normal - Windows and some of your other programs like Antivirus load all sorts of programs and services into memory when it boots.  1GB is quite usual.
Have a look in Task Manager -> Processes and you will see what it has loaded.
:wink:
Hi Will,
:wink:
Will1111
Hi Blencogo,
I checked out the Task Manager and you were right.  There were lots of programmes running as soon as I had turned the computer on.
Thanks again for your help,
Will
