[size=18]
My PCG-X18 needs Memory upgrade. The tutorials do not tell me how to remove the stoppers at the bottom of the keyboard. I tried and I could not remove them. Help.
Cool I got a x18 lappy as well, I'm not ever selling it, I'm keeping it for show, maybe as an ornament. :smileygrin:
If I get home this weekend and can find the old X9 (dad has it) i'll take a few photos and try to upload them here
If it still doesn't work I think I will just trade it in for a more powerful VAIO.
You do not remove the stop tabs. They are on springs. Just move them towards you (assuming you are facing the computer). The keybard should pop up (assuming you have removed the screw from underneath the computer which locks the keybard down - Page 117)
if you downlaod the manual for your machine
http://www.vaio-link.com/manuals/manuals.asp?l=en&m=146&c=0
you will find s tutorial on pages 114 - 120
It sounds like teh memory is either defective, or not installed propery
Does the laptop work with the original memory re-installed??
If it does, then your new memory is not working, or is an incorrect specification. Speak to the supplier
Sounds like dodgy RAM.
Yep. The memory is kaput. Take it back to the supplier and get a refund.
Many here suggest using www.crucial.com for memory.
