Hi all
howto obtain factory restore media? after a COMPLETE HD FAILURE - was not possible using to retreive the media fro the failed hd.
I have downloaded all the necessary media from sony's website - for re-installing - but not very sucessful to many options and many problems would work after installing.
. I have a VGN-AR&!M laptop with vista or win7 to new hd.
can someone advise please.
I'm 78yrs old.
regards
note.has anyone obtained the factory restore media from Sony - I'm willing to pay a fair fee for this.
Solved! Go to Solution.
Hi I_middleton,
You can purchase a set of recovery media from Sony Support. You will need to call the out of warranty telephone number 0905 0310006 (Fixed: 0.35£/min).
Rich
Hi
thanks for reply - will do that
regards len
