I am in the process of a bios update using the windows installer and it has now been running for 2 hours. There is occasional hard drive activity.
Please does anyone know how long this normally takes ?
I don't want to stop the instal in case it all goes wrong.
Any advice would be most appreciated.
Dave
Solved! Go to Solution.
Hi, thanks for that.
I waited for a day and then stopped instal by clicking on the red cross. There was another screen behind which gave me the option to terminate.
Not going ahead with bios update as have managed to sort most of the problems now.
All I need now is to get the motion eye camera working but no sign of drivers on Sony site.
Thanks again for your help.
Dave
Hi Rich,
yes thats the bios I'm installing .
I used the Sony update facility and it was downloaded from there.
Any advice appreciated.
Dave
Hi Rich,
thanks for the advice.
I'll leave it overnight and see what happens.
If it has messed up is there a way of getting to reload bios at startup ? eg. "boot blocker"
Dave
Be patience. The speed of upgrading will depend on how old your computer. It means it loses it's potential speed when you bought it from the store.
Dave
Hi Dave,
If there are no drivers listed for the camera on the Support site then it uses native windows drivers.
What is the problem and is the device showing in Device Manager?
Rich
Hi Rich,
yes its showing as working in device manager.
Just wanted to access it to see if working okay.
Dave
Hi Dave,
Do you have ArcSoft WebCam Companion installed? You can test the camera with this or try Skype.
Rich
