When i click the attach button on message the keyboard pops up, hence i can't select anything to attach on the message body.
Solved! Go to Solution.
@Hampus This is a problem with the ROM itslef u can see i am running on safe mode, Don't recommend me to do a clean install of the rom cause my ROM is a clean install did it few days ago.
Could you send me your IMEI-number in a personal message?
http://support.sonymobile.com/global-en/xperiaz2/userguide/IMEI-number/
IMEI SENT.
I'm experiencing this bug too. I'm not able to attach anything to text/sms messages. Any resolution?
I have exactly the same problem. Anything to fix this????
Yep, having the exact same issue.
If there's an existing conversation thread, bringing up the attachment options (after you tap the paperclip) doesn't work, as the keyboard "hides" it.
A work around is to press the "windows" button (square at the bottom of the screen to change apps), and go back to the messaging app.
Please advise of a fix, and if you need a video, happy to provide.
Could you elaborate? do you have the correct APN settings? do you experience the same with other messaging apps? test Google Messenger
