When i click the attach button on message the keyboard pops up, hence i can't select anything to attach on the message body.
Solved! Go to Solution.
I had the same issue it's caused by a third party apps, for me omni swipe app was the problem i uninstalled it it fixes the issue
i have this issue for several months now. indeed, i have installed omni swipe 'coz i find it cool. lol will try the settings as mentioned on this thread first. if it will not work, will uninstall and see if it'll fix this issue. will keep you guys updated. cheers!
If you have cleanmaster installed, enter the app, go to tools and disable ISWIPE. Solved the same problem in my phone.
