MESSAGE ATTACHMENT BUG ON LOLLIPOP
Tasfique
When i click the attach button on message the keyboard pops up, hence i can't select anything to attach on the message body.Screenshot_2015-03-31-10-05-17.pngScreenshot_2015-03-31-10-05-24.png
Tasfique
It caused due to an app called lazy swipe after uninstall it is back to normal
29 REPLIES 29
profile.country.RO.title
_alexdon_
Try settings-apps-all-messages,force stop and clear data. Restart your device. Make sure you have a backup of your messages.
alexdon
SophiaW
Enthusiast
Hi Tasfique
Are you tapping right on the paperclip rather than the area that says 'Write message'?
Tasfique
Yes I am tapping on the paper clip Expressionless_Face
Tasfique
Tried it, same issue. Is it just me or others on lollipop facing the same issue?
_alexdon_
@Hampus @Johan could you take a look?
alexdon
Hampus
Champion
It works fine for me, do you experience this for all your conversations and/or a new text message? And by the look of your screenshots, it looks like you are using a third party keyboard. Could you try to change to Xperia Keyboard to see if you experience the same behaviour? Otherwise, try to boot the phone into safe mode to see if same thing happens:
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Tasfique
I am using Google keyboard, even with Xperia keyboard same thing happens. This issue persist when writing new message or reply to a message etc... I can see the attachment menu for a mili second then it gets covered by the keyboard
Hampus
Champion
And what about safe mode? Did you also try to boot the phone into safe mode?
Tasfique
Yep tried it on safe mode too. Here is a video of the problem
https://www.youtube.com/watch?v=LXRAN2kJins
