New WinDVD BD update 8.0.9.301_3 dated 17.03.08
marcoda
Has anyone had any luck installing this update?
Tried with my FZ21Z running Vista and get message "a fatal error has occurred while installing WinDVD" at the Installshield Wizard. The green progress bar only gets half way.
Any ideas?
109 REPLIES 109
heliman001
Having exactly the same prob green bar quits half way cant find a solution :cry:
marcoda
Hi heliman001
Have raised this as an e-query.
I'll post here if I get anything sensible out of Sony Support.
oldcrow
Same problem on my AR51M. Full green bar, then 'fatal error'
leekendr
installed fine here, on my FZ21M running vista.
so it works for some and not for others
Windvd 9 is out now, so might take a look at that when i can get hold of it
squashme
same here it wont install at all and vaio cs are closed now :slight_frown: :slight_frown:
Can you all check which version of WinDVD BD you already have installed and post the answer here?
It will be the first question that Vaio-Link will ask, so if we can give them some info, it may help get a solution.
Open WinDVD BD -> Right-Click on the WinDVD screen -> Settings -> select the final Tab and read the Version.
:thinking:
luminessence
I've got the same problem with my FZ21Z and my WinDVD version is: 8.0 DXVA B08.425
best regards,
p.
marcoda
:thinking:
Hi Blencogo
I'm running WinDVD BD version 8.0 DXVA B08.425
Sanddie55
:thinking:
Hi I have the same problem, I have a viao ar51J and the version of winDVD BD is 8.0 DXVA B08.425. I thought it had downloaded but, after reading it again it says it had failed, and now I cannot get it to download at all.
