Has anyone had any luck installing this update?
Tried with my FZ21Z running Vista and get message "a fatal error has occurred while installing WinDVD" at the Installshield Wizard. The green progress bar only gets half way.
Any ideas?
My laptop is pretty new so it must be almost factory settings, i havent changed much! but i still have the error.
I recently purchased the AR61S but can't play blu-ray discs properly. The playback is extremely slow and jerky (if there's any at all).
The paperwork I got with the laptop warned me this would happen and told me to download and install the latest update. However, when I tried to install this update, vaio update told me it was unsuccessful and that it needs to be installed manually. When installed manually, the computer tells me it's successfull but when the computer restarts and vaio update re-opens, it tells me the update failed to install.
I tried doing this several times both before and after vista sp1 with no results. I am able to play back blu ray discs perfectly using PowerDVD Ultra but the High Definition playback doesn't seem so high. In any case, this confirms the problem is software related and not hardware.
When is Sony going to release a working update?
Many thanks.
P.S. My WinDVD version is 8.0 DXVA B09.254
blada blada blada..."A fatal error has occured while installing WinDVD" - got to 1/4 of the green bar. AR51SU.
Hi Nintensity,
are you able to recover your Vaio back to factory settings and then try to install the Win DVD 8.0.9.301_3 update.?
Hi Nintensity,
what does this involve? will i lose my updates and programs?
Hi Nintensity,
just wanted to say that for my vaio running Vista it went smooth. No problems.
Regards,
Rafal.
Hi, own a AR41S, same problem here. Fatal error after 1/3 of the installation. Current version is 8.0.8.425 and no SP1.
I am not restoring my machine to hope it works, Sony needs to solve this or I buy other equipment next time. I am also having issues with my remote, only works 2 of 10 times. For this kind of money I expect all issues to be resolved.
kendo88 posted: installed fine here, on my FZ21M running vista.
NetHolik posted: Hi,
kingpuiwong posted:my WinDVD version is 8.0 DXVA B08.425, on a FZ21M.
luminessence posted:same problem with my FZ21Z and my WinDVD version is: 8.0 DXVA B08.425
I'm getting the same error when trying to install the update.
My Vaio is running Vista (no sp1 though) and 8.0 DXVA B08.425
Is it a good idea to uninstall the old version first? I wasn't sure as I have done this before and found out that the new versions are update versions and won't install if the original has been removed.
