Android TV - Youtube lip-sync is very bad?
Risc0n
Since the last couple of updates Youtube lipsync has been horrible, I mean really horrible. Some videos are fine, however I have a video you can test below that is reproducable.
Ghostbusters trailer - https://www.youtube.com/watch?v=w3ugHP-yZXw
This is direct through the TV or via my Sony 1050 AV receiver using ARC.
55X850C
31 REPLIES 31
Hi all
I have tested this on my TV and outputting audio via a Sony AV Receiver and have no problems.
If anyone else is having problems please reply in this thread.
profile.country.SE.title
blomman00
something is broken with arc + youtube + yamaha reciver
switching off arc and lipsync is perfect...
Prior20
Hmmm odd i get this problem when casting surley thats not using ARC ?
petsmart
Just posted in the main thread. I am having delay on YouTube as well since the latest update and did not have this issue prior.  55x8509c. Connected to Sony reciever via hdmi.
Hi all
Ive added this to the bugs and issues thread.
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2040020
Tomas_90
Regarding " Issue appears to exist when TV is connected to an AV Receiver via HDMI-ARC "
I have the Lip-Sync problem too but i haven't got any AV Reciever connected. Just the TV and nothing else.
@Tomas_90 - thanks for that info. Will correct.
petsmart
Hi all,
I suspect I know the anser but im going to ask anyway! Is there any update or confirmation of this issue?
It's particulary bad the delay since the last update.
cheers
Hi there
Unfortunately there are no updates thus far.
Oddbin
Just wanted to add that I get lip sync issues and have almost since I bought my kd55x8509C in September 2015. TV is connected to a ct-380 via arc that was purchased alongside the TV. Factory reset after every update this year but the issue remains on every YouTube video, although some are worse than others. Pause and start can sometimes being the sync back for a short period but not always.
