RDR-HXD890 - Freeview EPG Not working
brian_mk
My RDR-HXD890 has been stuck displaying 'UPDATING' for at least 2 days.
All front panel buttons & remote have no effect.
After Power cycling, the machine returned to the same state.
After searching Internet forums, I found many posts from people with the same issue. Most were dated around 2019.
I tried most of the suggestions:-
A Soft Reset got the machine out of update mode but EPG no longer works and, following auto-tuning, all BBC channels are missing. All other Freeview channels were found.
A Factory Reset did not fix the problem.
The machine displays Software Version 115. I tried to initiate a manual firmware update but no updates were found.
Has there been a recent change with Freeview EPG such that it is no longer compatible with this machine?
83 REPLIES 83
Mooly01
Piscie
Community Team
Hey all! Have you tried resetting the device: page 150? Make sure you reset it from the mains first.
Mooly01
Hi Piscie, I'm afraid the problem is much more deep seated than something a reset can fix. The issue is incorrect coding in the EPG data structure. Even if you think a reset has 'fixed' it the issue returns at the next scheduled EPG update time.
Freeview UK are aware of the issue.
Camo_King
Here we go again!
Freeview have created another EPG update and my machine has been updating for 12hrs now. My machine is now unusable. Last time it took 3 days before everything was back to normal 😛
liketv
Friday August 25th 2023 17:00
Problem that started Thurs 24.08.23 has now been fixed. Need to retune, and all channels should be there.
liketv
UNFORTUNATELY, THIS FIXED WAS VERY SHORT-LIVED!
PatJW1
Yes, I spoke too soon. From 2pm update it's been stuck on update. Just switched off holding on/off switch and straight back on with same. No EPG and no BBC
No_Pic
Factory reset and 'Easy setup' at 25/8/23 17:00 did not work and the problem persisted.
Repeated the above (after an email from Freeview confirming a fix) at 17:10 and it was all working.
Have just switched the Sony on again 17:50 and BBC 1 and BBC 2 appear as expected.
The overnight EPG updates will determine whether it really is fixed (until the next time!)
liketv
Question for No_Pic; has your Sony retained the BBC channels? After the supposed fix around 5pm, when they were ok for a few minutes, mine now only shows them for a couple of seconds.
