Android TV - Bugs and Issues
Hello all
The aim of this thread is to collate all the issues that are currently outstanding and to provide feedback to everyone in this thread. This thread will be a work in progress and updates on various reported issues will be posted back here on the pages below.
Only issues that can be confirmed by multiple people will be posted here.
NOTE: For anyone experiencing other issues not mentioned here - can you please ensure that you factory reset the TV.   Instructions are located: HERE
Update: Due to some TVs that will be on Marshmallow and others that will be on Nougat, this list will be separated into two (ATV1 and ATV2 - see below for model numbers for the difference).  If the fault occurs on both versions of Android, it will be listed under both lists.
Current Faults (ATV 1 - Marshmallow):
  1. Lip Sync issues - see HERE
  2. [Re-Opened] IR Blaster issues - see HERE
  3. Restricted Profile - No iPlayer - see HERE
  4. Satellite Channels Re-Sorting Itself Automatically - see HERE
  5. TV Turning Itself ON - see HERE
  6. Bluetooth Randomly Disabling Itself - see HERE
  7. Info Button not showing all information via HDMI sources - see HERE
  8. No 3D Options in Action Menu - see HERE
  9. Crackling audio on high bass when using Clear Audio+ - see HERE
  10. Intermittent Network Connectivity using WiFi or Ethernet - see HERE
  11. HDD Recording - HDD not powering down - see HERE
  12. Satellite EPG: Lack of information - see HERE
  13. Custom Label for Inputs not quite working properly - see HERE
  14. Football mode with AV Receivers Issue - see HERE
  15. HDMI Handshake Issues interferring with other equipment - see HERE
  16. Not Retaining Picture Mode/Colour Temp - see HERE
  17. Un-responsive TV after being in standby for a while - see HERE
  18. Wide Mode unavailable - see HERE
  19. Juddery Playback on USB HDD Recordings - see HERE
  20. Double Overlay of top Info Banners - see HERE
  21. Delay in changing volume using TV remote to external audio system via HDMI-ARC - see HERE
  22. Video App - Aspect Ratio 2:35:1 displaying incorrectly (stretched) - see HERE
  23. Amazon Video - Lip Sync Issues - see HERE
  24. Favorites List in EPG - Closing when changing to external input or app - see HERE
  25. Amazon Video - Juddering Issues - see HERE
  26. Cannot grant 'write' permissions on USB Drives - see HERE
  27. USB Drive used for internal storage keeps disappearing - see HERE
  28. EPG fails to update is 'Auto Service Update' is disabled - see HERE
  29. 3D within 3rd party apps "Function not supported" Error - see HERE
  30. Info Banner - Not changing description from Now to Next - see HERE
  31. TV Randomly Rebooting - see HERE
  32. Netflix Buffering to 25% then freezing - see HERE
  33. WiFi will not connect on hidden SSID using 5Ghz band - see HERE
  34. All4 App - TV show restarts from beginning at end of first advert break - see HERE
  35. WiFi - Unable to connect when ethernet cable is connected - see HERE
  36. Amazon App - Un-pausing when daydream is activated Issue - see HERE
  37. Amazon App - Failing to correctly play first time - see HERE
  38. Volume Bar - Display Issues - see HERE
  39. MotionFlow issues on aspect ratios other than 16:9 - see HERE
  40. YouTube app (v2.0) - 4K Issues - see HERE
Current Faults (ATV 2 - Nougat):
  1. Info Banner - Displays randomly when using HDMI inputs - see HERE
  2. Volume Bar - Display Issues - see HERE
  3. MotionFlow issues on aspect ratios other than 16:9 - see HERE
  4. YouTube app (v2.0) - 4K Issues - see HERE
  5. Colour Settings not being retained correctly - see HERE
Issues Resolved/Closed:
Spoiler
  1. [RESOLVED] Casting not working - see HERE
  2. [RESOLVED] Pop up message 'Screen Format' - see HERE
  3. [RESOLVED - Individually] Problems updating the Firmware - see HERE
  4. [RESOLVED] No 5.1 Audio from various apps - see HERE
  5. [RESOLVED] Error message: “Unfortunately, HbbTvLauncher has stopped.” - see HERE
  6. [RESOLVED] TV SideView - Netherlands - see HERE
  7. [RESOLVED] Auto brightness issues - see HERE
  8. [WORK AROUND FIX] Disabling Daydream - see HERE
  9. [RESOLVED] WIFI Issues - see HERE
  10. [RESOLVED] YouView: Discover showing year not title - see HERE
  11. [RESOLVED] Amazon Prime UHD License Error - see HERE
  12. [RESOLVED] YouView Disabled after 10 December FW update - see HERE
  13. [RESOLVED] Google Play Store crashes when trying to install apps - see HERE
  14. [RESOLVED] Google Play Store is Empty - see HERE
  15. [RESOLVED] Incorrect System Time - see HERE
  16. [RESOLVED] VEVO App - Adjusting volume stops playback of music - see HERE
  17. [RESOLVED] Image Stutter on BT Ultra HD & Sky Q Silver Boxes - see HERE
  18. [RESOLVED] YouView Sluggish and Unresponsive - see HERE
  19. [RESOLVED] Duplication of HDMI Input Sources - see HERE
  20. [RESOLVED] TV Guide flickers - see HERE
  21. [RESOLVED] Video App aspect set to FullScreen - see HERE
  22. [RESOLVED] Auto Picture Mode is not working correctly - see HERE
  23. [RESOLVED] Unresponsive Remote Control - see HERE
  24. [RESOLVED] YouTube LipSync issues - see HERE
  25. [RESOLVED] Netflix Issue (UI-800-3) with BT HomeHub - see HERE
  26. [RESOLVED] Disabled Wifi switches itself back on - see HERE
  27. [RESOLVED] Picture but NO Sound - see HERE
  28. [RESOLVED] Blank screen with sound - see HERE
  29. [RESOLVED] Bluetooth randomly switching itself on after being disabled - see HERE
  30. [RESOLVED] Amber/Green Lights Blinking after Marshmallow Update - See HERE
    [RESOLVED] Customise TV Key greyed out when YouView is enabled - see HERE
73 REPLIES 73
[RESOLVED] Casting Not Working
Problem:
Unable to cast from various devices to the tv. See main discussion thread: HERE
Reported by:
Various people
Updates:
16-10-2015:
Sony has confirmed this issue and is in contact with Google to resolve this, as it appears its a global issue and not just EU.  This is being addressed with urgency.
17-10-2015:
Google has issued an update to its GoogleCast software which has resolved this issue. Please ensure that you have this version: 1.16.45911
19-10-2015:
Sony has issued the following statement - however if anyone is still having issues even after updating, please factory reset the tv
http://www.sony.co.uk/support/en/content/cnt-hn/prd-tvhc/GoogleCast-temporarily-unavailable
Problem:
There are two issues in regards to this problem:
  1. Non 3D - A message intimittently pops up on the TV screen with the Screen Format information.
  2. 3D - A discussion thread has been created HERE
Video of problem:
https://community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues/m-p/2039962#M34571
Reported by:
RiscOn
Nibor99
Frogger38
Various
Updates:
16-10-2015 - Issue has been reported to Sony, awaiting feedback
20-10-2015 - Sony Engineers are conducting their investigations on this issue
23-10-2015 - Confirmed that this can be replicated in testing. Passed to Sony Japan engineers to resolve.
22-12-2015 - A new firmware was release for Ireland and EU countries that resolves this issue
(version PKG3.155).  Unfortunately for UK, thid update will be rolled out at the end of February 2016
07-02-2016 - This issue has now been resolved
[RESOLVED - Individually] Problems updating the firmware
Problem:
Cannot update the firmware via the TV or via USB. See discussion thread: HERE
Resolution:
Alternative instructions can be provided on a case by case basis.  Please send a Private Message to one of the forum Experts for these instructions (i.e. Quinnicus) or alternatively contact Sony Support.
Reported by:
Various forum members
Updates:
20-10-2015 - Sony are currently awaiting for an alternative release of this firmware and instructions for those that are having problems. Even though the potential fix above has worked for some, it is more of a mystery because two firmware files actually has no effect.
30-10-2015 - Alternative instructions can be provided on a case-by-case basis.
Problem:
No 5.1 Audio from various apps (i.e. Amazon Video, Google Movies, Plex)
Reported by:
Heckie
Sassbs
Updates:
20-10-2015 - Amazon Video should have 5.1 Audio before 24 December as per Support page http://www.sony.co.uk/support/en/article/73499 - No information about other apps as this is up to the other providers in conjuction with their partnership with Sony.
15-01-2016 - This is ongoing, but technically it is up to the individual companies to develope their app for the Android TV.
07-11-2016 - With the release of firmware 3.533 (7 November 2016), there is now 5.1 Surround Sound support within the Amazon App.
13-12-2016 - AC3 Pass-though works for Google Play Movies and Plex
Problem:
An error message pops up on the screen saying: “Unfortunately, HbbTvLauncher has stopped.”
Photo:
https://community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues/m-p/2037793#M34336
Reported by:
Rdlowry
Anjenki75
Updates:
15-01-2016 - This does not appear to be an issue any longer. Presumed resolved via a recent FW release in December 2015.  If anyone has this issue please create a thread/topic on these forums
[RESOLVED] TV Guide Flickers
Problem:
TV Guide – When accessing the guide, it flashes on-off-on before you can use it.
Reported by:
Frogger38 HERE
Scoopy6 HERE
Jimmyjamh HERE
Updates:
20-10-2015 - Sony Engineers are conducting their investigations on this issue - further testing by Sony required as they are unable to replicate this currently
15-01-2016 - This appears to have been resolved.  Not heard any complaints for a while on this and have tested both EPGs of default and YouView with success.
10-03-2016 - This issue is being re-opened due to a couple of forum members confirming that this is still an issue
13-12-2016 - It has been reported that this issue no longer occurs under Marshmallow (Android 6.0)
25-02-2017 - With the Marshmallow (Android 6.0) firmware update that was released on the 22nd February, this issue has been resolved.
Problem:
Since the October update, it is being reported in the Netherlands that TV SideView app is no longer working.
Reported By:
Netherlands
NicolaiLarsen91 HERE
Pa3iea
Potential fix:
After you have factory reset the TV, you must delete the TV from the SideView app and pair it back up again
Updates:
16-10-2015 - Has been reported to Sony, awaiting feedback.
20-10-2015 - Issue is not only the Netherlands, awaiting feedback on a workaround fix above
15-01-2016 - Issue has been resolved
Problem:
Various people have been reporting that the screen goes blank either upon switching TV on or whilst already in use however audio is still being heard.
Further information:
https://community.sony.co.uk/t5/televisions/2015-android-tv-blank-screen-issue/m-p/2043703
Temporary Fix:
Power cycle the TV.
Reported by:
Frogger38 HERE
John.Pringle HERE and HERE
Frankie1g HERE
Dspencer999 HERE
RiscOn HERE
Updates
17-10-2015 - Reported to Sony, awaiting feedback.
22-10-2015 - Additional information has been requested by Sony from the community.
10-12-2015 - New firmware released on 10 December to fix this issue (PKG2.645.0052EUA - for UK).  Awaiting for community to confirm if this is fixed.
15-01-2016 - This issue has been resolved for EU countries.  Awaiting update for UK, due end of Feb.  Had confirmation from other forum members stating that this is NOT resolved.  In fact Tarzion and Komparko are claiming that this issue is worse FW version 3.169 than 3.155.  Also seen other posts on this forum stating its not fixed
07-02-2016 - Issue is ongoing
25-02-2017 - There has been no further complaints about this issue for more than 6 months - with the release of the Marshmallow (Android 6.0) update, it is therefore assumed resolved.  This can always be re-opened again at a later date if required.
Lip Sync Issues
Problem:
Even after the 13 Oct update, it still appears that some people stil have the audio/video is out of sync (i.e. lip sync)
Reported by:
Johndstephen83 HERE
UKPiglet HERE
N.mccormack HERE
SingingDwarf HERE
Updates:
17-10-2015 - reported to Sony, awaiting feedback
20-10-2015 - Sony requires more information to investigate this issue
15-01-2016 - Issue seems to be narrowed down to people who are using external audio systems connected via optical.
07-02-2016 - Issue still ongoing and under investigation.  Seems quite complex
